There's two fuses. One will be tied to something that's hot all the time such as interior lights or horn.
What is the symptom and type of radio? If the clock display works, the fuses are good. If you have a cassette player, and the display flickers a little when you cycle the power switch, suspect burned contacts on the switch. I've repaired hundreds of those.
caradiodoc
Jun 19, 2009 at 4:39 PM
