Welcome to the forum. How long since a tune-up? Check for primary voltage at the coil, engine cranking, dark green wire with orange tracer. check for trouble codes. You should be able to get some mil codes by cycling the ignition switch. Turn key just till dash lites come on, no further. Cycle key, on--off, on--off, on, the the mil starts flashing, you count the flashes to get the codes. Your looking for two digit codes.
Feb 7, 2010 at 1:19 PM
