1993 Plymouth Acclaim Fuel injector wire harness
1993 PLYMOUTH ACCLAIM
ALUCARD1313
Electrical problem
1993 Plymouth Acclaim 6 cyl Automatic
I need a diagram of the order the fuel injector plugs are supposed be attached. Every time I've hooked them up I can only get 4 of the 6 to fire, and every time I change the order of the injector plugs it changes witch ones fire.
Oct 17, 2010 at 10:25 PM
JDL
  • 16,098 POSTS
I'd check voltage to injectors, first, engine cranking. You might do an ohms test on all injectors, compare readings, everything off. Any applicable mil codes? Injector 1 is cylinder 1 and so on. The info I looked at was 3.0L.
https://www.2carpros.com/forum/automotive_pictures/170934_plymouth_acclaim_injectors_1.jpg
https://www.2carpros.com/forum/automotive_pictures/170934_acclaim_firing_order_1.jpg
Oct 18, 2010 at 12:02 PM
