1992 Plymouth Acclaim Fuel Pump
1992 PLYMOUTH ACCLAIM
144,009 MILES • 4 CYL • FWD • AUTOMATIC
FJGRAHAM
Obtained 1992 Plymouth Acclaim that hadn't been
driven 3 years. Changed oil and coolant. Attempted to start . Electric fulel pump not pumping. Trying to
check for voltage to fuel pump. Need to know where
voltage supply comes from. Tried to trace from fuse
link. Any help would be appreciated. Trying to get
started so grandson can help take mother to doctor.
Jun 7, 2008 at 3:12 PM
Hi:
The fuel pump relay is located in the power distribution center under the hood. Check the relay. If it's good, chances are the pump is bad.
Oct 10, 2008 at 9:03 PM
