1992 Plymouth Acclaim Cooling Fan
1992 PLYMOUTH ACCLAIM
149,000 MILES • 6 CYL • FWD • AUTOMATIC
GINAANDY
When my car heats up the fan does not come on.
I replaced the relay switches and it still doesn't work.
What else should I check.
Thank you,
Gina
May 28, 2008 at 10:28 PM
MMPRINCE4000
  • 8,548 POSTS
Unplug the fan electrical connection and make some jumpers to connect directly to battery. If fan works then relay, fuse, fan switch or wiring to fan is bad.
If it doesn't work then fan motor is bad and fan would need to be replaced.
May 29, 2008 at 4:11 AM
