1991 Plymouth Acclaim Speedometer and Odometer do not work.
1991 PLYMOUTH ACCLAIM
104,641 MILES • 4 CYL • FWD • AUTOMATIC
FORDMAN52205
first thing that happened was my odometer stopped working completely,then a wekk or two later so did the speedo. Do I need a new speed sensor or a new gauge?
Oct 14, 2008 at 7:52 PM
I believe this year still has a speedo cable. If you look behind the dash, you will see it plugging into the back of the speedo. Remove it, and try to turn the cable on the inside. If it turns freely, the cable is broken and needs replaced. If you can't turn it, the speedo has internal problems and needs replaced.
Mar 20, 2009 at 10:18 PM
