hi again, i already asked about my car. I dont have fuel from the fuel pump, but the car start with no problem with starter fluid. i dont need to check the ADS relay (i m not sure about the name, but is the relay that manage fuel pump, spark, etc) because the engine runs. I check the fuel pump plug and there is no voltage. I have a wiring diagram a they say that fuse number 2 is for the fuel pump, so i check all the fuses in the fuse box and everything is ok. Could be another fuse in another place? i m pretty sure that is just a wiring problem, but i cant find the wiring diagram or the way to fix it. thanks
Mar 15, 2010 at 7:33 PM
