car feels rough when driving
2010 MAZDA 121
110,000 MILES • 2.2L • TURBO • FWD • MANUAL
DELBOI92
Hi, I have a 6 2.2 ts2 and when I press my brakes my car feels like the ABS is kicking in because the brakes feel like there on then off then on then off and the pedal pulsates and the steering wheel shakes. when driving the car feels a little rough and not as smooth as it use to be.
I have had new pads and discs on front.
New pads on back.
New engine mount.
Tracking done.
All tires ballances.
Bought all new alloys with new tyres and tracking again. I still cannot find the problem. The car has been garage a few times and they could not find the problem. They have checked all springs, struts, ball joints, bearings, etc. it passed a mot with no problems.
Do you have any ideas? Please.
Thanks,
Nathan dell
Nov 7, 2016 at 4:09 PM
AL514
  • 5,465 POSTS
If the pedal is pulsing very fast, which I am sure you know what ABS feels like when you slam on the brakes. This can be caused by the ABS wheel sensor not having the correct air gap to the reluctor ring. Check each sensor at each wheel. sometimes rust build up can cause the sensor gap to be off slightly and that's all it takes for the ABS to kick in, The sensors each have a small screw holding them into the steering knuckle just behind the brake rotor. You can unscrew it and take it out and see if there is a rust build up in there or if something else is interfering with the sensor. Since I am assuming the ABS light is not on, because this would disable the system, the ABS is doing its job, just being activated by something at the wrong time. visually inspect the wiring and ABS sensors. Hope this helps some.
Nov 7, 2016 at 4:50 PM
AL514
  • 5,465 POSTS
it is a pretty sensitive system for good reason, prevent lock up.
Nov 7, 2016 at 4:51 PM
