Hi, it is definitely a cable clutch. I have just cured the problem. Under the hood of the engine compartment on the inner bulk head just below the wipers the cable goes through the bulk head. There is a thick rubber washer and star shaped nut, which was loose I tightened it by hand and now the play on the cable has gone. The clutch pedal has come up and now to select gears it is not necessary to depress clutch to the floor.
Just letting you know in case anyone else has this same problem. Thank you for your help and Merry Christmas!
Dec 26, 2017 at 7:32 AM
