Piston swap
2003 PONTIAC VIBE
90,000 MILES • 1.8L • 4 CYL • MANUAL
BENJAMIN YOUNG
  • 7 POSTS
I have the car listed above it is the GT model. Two of the four piston are busted. since the car is built on a Toyota engine i would like to know if i can use piston from another Toyota engine that is not a Pontiac vehicle and if so what vehicle because it is extremely difficult to find another one even or scrap where i live? Thanks
Sep 28, 2017 at 11:06 AM
STEVE W.
  • 15,113 POSTS
You would be better off getting an entire engine to swap in. That is because the pistons, con-rods and crankshaft are balanced as a unit. You cannot just swap them with a different set because the balance difference will do damage. Also, if the pistons were broke there is a good chance the block and crank were damaged.
Where are you located? There are a lot of salvage yards that ship parts and even complete engines.
Sep 28, 2017 at 11:15 AM
BENJAMIN YOUNG
  • 7 POSTS
That is really good to know. I am unfortunately not located in the U.S. I live in Belize, Central America. Can you recommend any good salvage yards that do international shipping?
Sep 28, 2017 at 11:22 AM
STEVE W.
  • 15,113 POSTS
That could be a problem. The Vibe is basically a Matrix, but they did change some of the external engine items and the heat/AC system. The 1.8 GT engine itself is not Toyota, it is built by Yamaha. It was used in the 2003 Vibe and Matrix and the 2000-2003 Celica.
Shipping would probably double the cost of the engine. Looking at RockAuto.com. They show two versions of that engine. They do ship to Belize but a quick check shows that a long block alone would be close to $5,000.00! by the time it was shipped.
You might try going to car-part.com and searching around Texas or Louisiana and see if any of the yards ship to Belize.
You might try a dealer if there is one in country, they might be able to get a better price.
Sep 28, 2017 at 12:02 PM
BENJAMIN YOUNG
  • 7 POSTS
$5,000.00 is almost the price i payed for the car. I will keep my hopes up around here and see if anything comes around. Thanks for your help. I will also try your suggestions.
Sep 28, 2017 at 2:29 PM
Please let us know what you find.
Sep 29, 2017 at 9:56 AM
STEVE W.
  • 15,113 POSTS
That is what I expected. I would hunt around and see what you can find. Good luck. I am not sure how difficult it would be to import a complete car.
Sep 29, 2017 at 9:58 AM
BENJAMIN YOUNG
  • 7 POSTS
Unfortunately when I search on car-parts . com nothing would come up. I search the areas you recommended as well. What I need now is just a single piston for my vehicle because the connecting rod were damaged. I got a good one the other day from scrap which just leaves one more.
Sep 30, 2017 at 4:02 PM
BENJAMIN YOUNG
  • 7 POSTS
This is what i actually need. The rings of two pistons were damaged. I like i mentioned i got a good one the other from scrap with only leaves on piston left and im good to go but the problem is finding a matching one in the country. Sorry for all the back and forth guys.
Sep 30, 2017 at 4:08 PM
No problem, you cannot get just a rod cap because they are matched to one another, even if you find one it wont work because the cap will be off from the rod. If I am understanding you correctly.
Please let us know.
Sep 30, 2017 at 4:43 PM
BENJAMIN YOUNG
  • 7 POSTS
Good to know. So then I will need to get the entire piston and not just the rod. Thanks
Oct 1, 2017 at 10:58 AM
Please use 2CarPros anytime, we are here to help. Please tell a friend.
Oct 1, 2017 at 5:52 PM
BENJAMIN YOUNG
  • 7 POSTS
Definitely will. You guys are awesome!
Oct 3, 2017 at 9:14 AM
