pipe splits
2008 FORD MONDEO
145,000 MILES • 2.0L • TURBO • 2WD • MANUAL
PETER1961
Since August 2017 the same water pipe has split. the new pipe seems to last no more than five weeks. it seems to overheat when I am stuck in traffic not moving. after being in traffic the pipe splits with no warning, no lights or the temperature gauge moving.
Jan 27, 2018 at 5:25 AM
Good morning.
Is this a steel pipe or a rubber line? Can you post a picture for us to view?
The most common cause is excessive pressure. Has the engine overheated at any time?
Jan 27, 2018 at 5:48 AM
PETER1961
It is the rubber hose located at the back of battery. cannot photograph it or video. the engine has never overheated, there is no warning, the temperature gauge does not move. it seems to pop when stuck in traffic not moving .
Jan 27, 2018 at 5:55 AM
Okay thanks. Make sure you are using the correct style hose. coolant hoses need steel reinforced hosing to handle the pressure.
Also, check the radiator cap to be sure it is releasing pressure at the correct spec. if it does not then it will build too much pressure and the hose will fail.
Jan 27, 2018 at 6:00 AM
PETER1961
Thank you will pass this on to garage on Monday.
Jan 27, 2018 at 6:02 AM
You are welcome. Let us know if you need any other help.
Jan 27, 2018 at 6:03 AM
