Welcome to 2CarPros.
The blend air door actuator is under the dash on the HVAC unit. Here is a link that explains in general how one is replaced:
Here are the directions specific to your vehicle. I attached two pics. One shows the HVAC unit under the dash, and the other, I circled the actuator in question.
REMOVE OR DISCONNECT
1. Battery ground cable.
2. Instrument panel compartment for excess.
3. Electrical connection.
4. Screws.
5. Actuator.
ADJUST
1. Install the battery ground cable.
2. Electrical connection to the actuator.
3. Turn the ignition key to the accessory position.
4. Allow the actuator to position itself.
5. Turn off the ignition key.
6. Disconnect the electrical connection from the actuator.
7. Disconnect the battery ground cable.
INSTALL OR CONNECT
1. Actuator to the heater assembly.
2. Screws.
3. Electrical connection to the actuator.
4. Instrument panel compartment.
5. Battery ground cable.
Apr 30, 2021 at 2:07 PM
(Merged)
