Pinion shaft will not turn
2001 TOYOTA TACOMA
150,000 MILES • 2.7L • 4 CYL • 4WD • AUTOMATIC
Removed front differential to replace rotten oil pan. Now reinstalling front differential. But input or pinion shaft will not turn. Wire harness not plugged in, seal/driveshaft flange piece was removed. Concerned about a possible jam internally, etc. So holding off re-installation of differential until clarification.
Sep 16, 2016 at 7:25 AM
It sounds like you have too long of bolt in the wrong place, can you loosen/remove any bolt that would jam the gears or axle.
Please let us know what you find so it will help others.
Best, Ken
Sep 17, 2016 at 11:44 PM
