Truck suddenly stops moving while driving
2006 ISUZU D-MAX
150,000 MILES • 3.0L • 4 CYL • TURBO • 4WD • AUTOMATIC
SAMIR HOURANI
After driving continuously for one to two hours , it suddenly disengages with gears system (go neutral ), after switching ignition key off for a couple of minutes and start engine again driving becomes normal. Gear box was recently maintained ( replaced about fifteen pieces of gears) because of repeated "clicks" in gearbox . Mechanic replaced what he called " air sensor ", but the problem of the "sudden " of gearbox disengagement still on. Please advise.
Aug 31, 2016 at 12:35 PM
HMAC300
  • 48,601 POSTS
scan for codes it may be a wiring issue , connection or TCM problem.
Sep 1, 2016 at 6:58 AM
