anti-theft system disarm
2001 CHEVROLET IMPALA
100,000 MILES • 3.4L • 6 CYL • FWD • AUTOMATIC
FRANKBRU
  • 6 POSTS
Hi I have my instrument panel take out, i replaced the ignition cylinder with a used on that came with the key, i also want to replace the Anti-theft deterrent relay while the instrument panel is out, but i cant fine the relay and i know it exists because i bought the relay from a local parts store, so is it behind the radio ?? or is it behind the glove compartment ?? or maybe near the steering column ??
also could u give me the exact procedure with timing to relearn the password, the ignition cylinder, and the housing for the cylinder have been swapped out, so i need to relearn, have seen things about keeping the key in run postion for 10 minutes, a repair dude also told me to flip it back to the off after the 10 minutes is up and then repeat that,
really need the exact procedure to get the Impala to relearn,
hope u r fine, it is really nice here in NE, thx for the service u provide, c u
Sep 15, 2014 at 12:02 PM
HMAC300
  • 48,601 POSTS
because you have replaced the ignition lock your car needs to be reprogrammed for the security system to work. any garage with a scanner can do it. there is no relay in your system unless your were sold a RAP relay which is on the lh side fuse panel. or it was the remote control doorlock receiver which is in the upper center of dash.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Check out the diagrams (Below). Please let us know what happens.
Sep 15, 2014 at 12:28 PM
FRANKBRU
  • 6 POSTS
not true, there is an Anti-theft relay, it is a 2001 Impala 3.4, should have included that, i purchased the relay, it is different and comes with housing over the relay, so it is not in the normal places for relays, it is not in the fuse panel on the driver side, nor in the fuse panel on the passenger side, nor is it in the under the hood fuse / relay compartments, which makes sense because it is a theft deterrent device and should be difficult to access anyway,
but there is definitely an an anti-theft relay, called some chevy dealers around here, central MA and they are not helpful, called chevy / GM direct, the lady i talked to there was helpful and is going to have a District Manager talk to me, she sounded pretty concerned that the chevy dealers wouldn't help me out, so maybe she will reprimand them or the district manager will reprimand them, maybe the dealers concerns are safety related tho
outside of the airbag there is not a real safety issue, i have the battery terminal disconnected and took out the maxi fuse for the air pump, stopped a little while ago, didn't want the air bag going off while i worked on the dash/instrument console, is there anything else that should be done to prevent the air bags from going off accidentally ??
I have all the instrument panels out, ie everything is out,, just left with the big black plastic molding things that stretches across the dash and so i am going to take that out, right now i cant figure out how to get the top dash cover off, i took out the screws that hold that dash cover down in the front but something is holding it on in the back on both the left side and the right side too, , ie in the back near the windshield, any clues u can give me on that would be appreciated too???, the black molding thing has bolts maybe about 6-8 of them and it is loose on the bottom, ie not attached at the bottom of the molding,
thanks for the relearn procedure, the procedure u gave me is for a Pontiac Sunfire 2001, will that work on my 2001 Impala too ??
Thx Dude for ur help,
Sep 15, 2014 at 3:11 PM
HMAC300
  • 48,601 POSTS
take the screws out of the defrostervents to get the top off. I'm glad you now so much about your system because there is no relay powergoes form fuse to body module which ignition lock is connected to that there is no relay listed in any of our diagrams from GM as well as relay locations for that. Good luck on your quest but there isn't a relay .
Sep 15, 2014 at 3:24 PM
FRANKBRU
  • 6 POSTS
was just thinking about safety and do it your selfers, ie some of the DIY people are young and NOT aware of how important safety is, could u guys give the DIY crowd a dig dose of caution whenever someone is trying to do something that involves safety, aaaargh i watch too much news sometime and always seem to hear about DIY people that are NOT safety conscious so fyi
Sep 15, 2014 at 3:53 PM
FRANKBRU
  • 6 POSTS
dude i have the book and the electrical schematics and there definetly is a theft deterrent relay
FRANKBRU
  • 6 POSTS
besides the auto part store i got it from had it listed under the Impala 2001 parts and it is called an anti-theft deterrent relay, maybe call advanced auto parts and ask them,
Sep 15, 2014 at 3:56 PM
HMAC300
  • 48,601 POSTS
like I've said our schematics nor relay locations show that particular relay the on I looked up under rock auto listed it but it's not there in the schematics. i'have checked form 2000-2003 and none of them show it.
Sep 15, 2014 at 4:08 PM
FRANKBRU
  • 6 POSTS
the book with the electrical schematic that shows the anti-theft relay is the Haynes book for impala, etc, maybe u r right tho, i don't know how accurate the Haynes book is
thanks again tho, as far as the air bag goes is there anything i need to do to make sure they don't go off accidentally, ??
Sep 15, 2014 at 4:12 PM
HMAC300
  • 48,601 POSTS
kep battery disconnected til finished.
Sep 15, 2014 at 4:14 PM
