1993 Other Peugeot Models continuous Problems
1993 PEUGEOT
103,458 MILES • V12 • AWD • MANUAL
SMITH91
My peugoet 306 1993 1.9 Diesel is causing me to either jump start it or charge the battery every day! The battery is just 1 week old on monday and also when i took the key out of the ignition the right head light was continuously flashing can you please help me because im getting annoyed with it! Thanks
Dec 6, 2008 at 6:10 PM
BLUELIGHTNIN6
  • 16,542 POSTS
It sounds like you have a short circuit somewhere in the wiring. Whatever is causing the headlight to flash is, more than likely, the same thing that is draining the power from your battery. You need to check your wiring at the ignition assembly, headlight switch, and headlight assembly for any faulty wires.
Dec 6, 2008 at 11:47 PM
