Engine Mechanical problem
1985 Peugeot 505 4 cyl Two Wheel Drive Manual
The fuel pump in gas tank is working fine.
The fule pump on the drivers side, appears to be pumping OK. (It sounds like it is pumping)
The cylinders are getting too much fuel, (the cylinders are full, gas spraying every where). Where should I be looking to rectify the proplem. It is fuel injected, and I am working with out a manual...
Thanks so very much.-- Greg.
Sep 25, 2009 at 9:32 PM
