1997 Peugeot 407 problem with steering
1997 PEUGEOT 407
13,400 MILES • 6 CYL • FWD • MANUAL
NICOLA
when engine is running turn the steering wheel and it makes a crunching noies can you please try and point me in the right direction of what my cause this.
thank you.
Sep 1, 2008 at 3:12 PM
DR LOOT
  • 2,311 POSTS
your problem sounds like, you have dried up rubber bushings in the front end, when you go to these quick lube places to have your oil changed, make sure they lubricate the rubber bushings with silicone spray, at any rate, you can take your car to an alignment shop, have them check the alignment and at the same time if you have any warn parts in the front end thay will tell you at no charge $$$
Your contributions are welcomed, Thank You
Feb 13, 2009 at 1:34 PM
