2005 Peugeot 307 why does my car run soooo bad at the start
2005 PEUGEOT 307
GAZAM2O
Engine Performance problem
2005 Peugeot 307 4 cyl Two Wheel Drive 28500 miles
have had the car for about 2 years been ok last time i had it serviced was 10 months ago and ever since then been running bad its like it is misfireing and loss of power and then kicks in and drives ,but when i stop, it some times starts to do it again driven me mad 1.4 pertol dont know much about cars the so hope i can get an answer here
and the noise that comes from the engine some time when it does it sound bad it like jurks and backfires so any help would be welcome
Feb 5, 2010 at 11:37 AM
Check and test the following:
Oxygen sensor
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Feb 5, 2010 at 12:10 PM
