2003 Peugeot 307 engine stall
2003 PEUGEOT 307
94,000 MILES • 4 CYL • 2WD • AUTOMATIC
CHANLEGO
I have peugeot 307sw 2003 milage 92K. when I drive in long trafic jam above around 1 hour my engine stall, then I start again and run, but in few second engine stall again until I can not crank/start anymore. I waiting for 10 or 15 minute and engine working again, and can drive for long...... it only happen when I get 1 hour traffic jam..
I do diagnose next day, I run my engine in my gerage and idle....waiting about 1 hour in idle then my engine stall again. same symptoms.
I already change spark, fuel pump and ignation coil pack. the problem still happen.
in next day, I put some fan inside my engine that blow the air when in Idle, the result is my engine stall after 2 hours. if the fan do not turned it will be stall in 1 hour.
MY conclusion is something hot in my engine room. as you know when idle and engine stall all temperature engine is normal 90 dec.
I suspect crankshaft sensor (enginer speed sensor) it is posible this sensor can going bad when hot ? type of sensor magnetic or hall effect can be bad when it hot?
another info I alredy check the OBD code there are nothing error code.
and as your info If I running my car above 3-4 hours without long trafic jam my car is good, and doesn't stall.
please advice
Apr 7, 2009 at 11:59 AM
DAVE H
  • 13,384 POSTS
both types of sensor can cause a stall/non start when hot .. replace the sensor ...
May 23, 2009 at 4:21 AM
