I checked the vacuum lines,vacuum resorvoir and vacuum pump,found to be ok,i checked the mechnically wastegate valve,found to be ok,even i checked the electro solenoid valves,found to be ok,no leaks found from wastegate to vacuum pump.
Dec 19, 2009 at 12:13 PM
