2004 Peugeot 206 Car problem: Peugeot 206 overheating
2004 PEUGEOT 206
21,000 MILES • 4 CYL • 2WD • MANUAL
LETICIA CARRILLO
I've got a Peugeot 206 which is 5 years old. In the past four days it has started overheating. The temperature shoots up into the red and the sign of stop comes visible. The fans and temperature sensors have been checked but the problem has not been solved. All this has been done through a garage so its not just me guessing at what's wrong. I've looked online and seen others with the same problem but there doesn't seem to be any clear solutions. What should I do? It's the first time I have a problem with this car but it seems very serious.
Oct 1, 2009 at 11:16 PM
DAVE H
  • 13,384 POSTS
check/replace thermostat .. check/replace water pump .. have a compression test of the cylinders carried out .. flush the cooling system incase of a blockage !
Oct 27, 2009 at 3:03 AM
