2002 Peugeot 206
2002 PEUGEOT 206
BILLIEP1
Engine Mechanical problem
2002 Peugeot 206 Manual 60100 miles
MY WONT REV UP AS MUCH AS IT SHOULD. WHEN I TRY TO CHANGE TO A HIGHER GEAR AT THE SPEED THAT I USUALLY WOULD, THE CAR STARTS TO JUDDR AND THE STEARING WHEEL WOBBLES. WHEN THE CAR IS JUST TICKING OVER IT IS JUDDERING MORE THAN NORMAL AND JUST DOESNT SOUND RIGHT. THERE IS ALSO A WARNING LIGHT ON THE DASH BOARD THAT MEANS THERE IS SOMETHING WRONG WITH THE ENGINE DIAGNOSTICS.
Mar 20, 2010 at 12:52 PM
DAVE H
  • 13,384 POSTS
you need to have the vehicle plugged into a diagnostic computer to locate the cause of the fault .. probably bad coil/wire/plug
Mar 31, 2010 at 3:11 AM
