2000 Peugeot 206 engine oil
2000 PEUGEOT 206
ROBF
Engine Mechanical problem
2000 Peugeot 206 4 cyl Front Wheel Drive Manual 70k miles
i have noticed yellow scum on the underside of the engine oil refill cap. the oil from the dip stick looks ok. should i be concerned?
Feb 23, 2009 at 7:08 AM
DAVE H
  • 13,384 POSTS
some times a little yelowing is natural .. keep a check it does not get worse .. have the cylinders compression tested ..to check for gasket leaks !!
Mar 11, 2009 at 10:48 AM
