My vehicle continues to throw P0300 code at about 2,600 RPMs. I have checked compression and all cylinders are at or above 100 PSI, except #5, which is at about 91 PSI. I pulled both upstream O2 sensors and drove it. It still threw 3 codes: P0300, P0302, and P0305. I felt I had ruled out bad cats. I attached a fuel pressure gauge and drove it. Pressure good at 49 PSI most of time, periodically dipping to 40, and rising to 58. Did not dip in PSI, even when in process of throwing the 3 codes again. I replaced all six plugs with new Denso Iridium Long Life plugs. Also installed 3 new Denso Coils on bank 1. Swapped injectors between cylinders 2 and 4, then, again, between cylinders 4 and 6. Installed new aftermarket Fuel Injector Damper on Bank 1 Fuel rail. Thoroughly cleaned Throttle Body. The air filter seems clean. Installed new PCV valve and new 90-degree short Tubing between PCV Valve and bank 1 Valve cover.
I discovered a lot of oil had been leaking from collapsed seals in bank 1 valve cover, around coil tubes, mainly at cylinders 1 and 3, so replaced all gaskets in bank 1 valve cover. Then drove it and it now throws just the P0300 but is still throwing P0300! I am thinking of installing six Carquest Premium re manufactured Fuel Injectors, but not sure any of the current injectors are bad. Fuel pressure would hold at 40 psi for 45 minutes after turning engine off when I had the fuel pressure gauge attached directly to bank 2 fuel rail via banjo bolt, with attached Schrader Valve.
At one point, after one mechanic had driven it, with fuel pressure gauge still attached, fuel pressure slowly dropped to 39 briefly at one point, but then varied all the back way up to 70 PSI. Normally stayed around 49, though. The mechanic had ruled out that there was anything wrong with fuel pump, based on road testing with the external fuel pressure gauge connected.
Don’t know what to do next. Any thoughts appreciated.
Sincerely,
Roger
Sincerely,
Roger
Mar 31, 2023 at 12:25 AM
