Master cylinder was replaced brake pedal goes to the floor
2009 AUDI Q7
138,000 MILES
MARQUEEN ROBINSON SR.
Master cylinder was replaced and brakes bled.
Dec 22, 2019 at 9:08 PM
When you replaced the master cylinder, did you bench bleed the master cylinder prior to installing it?
If not, then I suspect you are not getting the air out of the system.
Here are a couple guides that will help with this:
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
However, the place to start if you did bench bleed it is to cap the master cylinder ports and see if you have a hard pedal. If you do, then you have a leak or air in the lines somewhere else in the system.
This means you need to add one line back in at a time until you find where the pedal gets soft again.
Please run through this and let us know what questions you have. Thanks
Oct 8, 2021 at 2:36 PM
