Pedal to loose
2002 NISSAN MAXIMA
160 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
MPLAIN
  • 24 POSTS
I changed the shoes and the caliper did not go in side. I replaced the caliper and bleeding the brake to many times and the pedal stayed down when the car started the pedal was to loose and went all the way down and it was hard to stop.
Apr 20, 2017 at 11:26 AM
HMAC300
  • 48,601 POSTS
take to a mechanic that has a scanner to open ABS valves to bleed system normally that is what is wrong. if you have access to a power bleeder that might take care of it rent it shops have those.
Apr 20, 2017 at 12:40 PM
