Brake light pedal position sensor wiring diagram needed?
2005 CHEVROLET MALIBU
130,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
KRISTINSAMANS
  • 8 POSTS
Hi, I need the wiring diagram for the brake light pedal position sensor in my car listed above please.
Apr 2, 2024 at 7:46 PM
Sure, here are the brake light switch wiring diagrams to the BCM. Check out the images (below). Let us know if you need anything else.
Apr 2, 2024 at 8:37 PM
KRISTINSAMANS
  • 8 POSTS
Okay, so I wired the switch, and my brake lights are still on when I turn off my head lights, they shut off but then I have none. I don't know what else to do or why that even happens.
Apr 3, 2024 at 4:11 AM
You might need to calibrate the brake light switch, here is how:
BRAKE PEDAL POSITION SENSOR CALIBRATION
CALIBRATION CRITERIA
The brake pedal position sensor (BPPS) receives a low reference signal and a 5-volt reference signal from the BCM. Whenever the brake pedal is applied, the BPPS applies a variable voltage signal to the BCM through the stop lamp switch signal circuit. The BPPS calibration must be performed after the BPPS or body control module (BCM) have been serviced. The calibration procedure will set BPPS home value. This value is used by the BCM to determine the action of the driver applying the brake system and to provide this information to the vehicle subsystems via the class 2 communication bus.
CALIBRATION PROCEDURE
- Install a scan tool.
- Turn ON the ignition, with the engine OFF.
- Select Diagnostics.
- Select the vehicle.
- Select Body and Accessories.
- Select Lighting Systems.
- Select Special Functions.
- Select BCM.
- Select the BPPS calibration procedure and follow the directions displayed on the screen.
Apr 3, 2024 at 8:33 AM
KRISTINSAMANS
  • 8 POSTS
Does it matter if my car is a 2005 Chevy Malibu classic? I just learned there was a regular Malibu and a classic version.
Apr 9, 2024 at 11:15 PM
It should be the same procedure.
Apr 10, 2024 at 9:18 AM
KRISTINSAMANS
  • 8 POSTS
Okay, cool, that's what I thought. Now how do I do this calibration meaning what is the cheapest tool I need to get or place I can go? I am very low on funds now.
Apr 11, 2024 at 1:40 PM
You can search Amazon for a scanner that can go into the BCM, if it doesn't work you can send it back.
Apr 12, 2024 at 5:39 PM
KRISTINSAMANS
  • 8 POSTS
I have a Innova 3170RS but I can't figure out how to do the calibration with it.
Apr 12, 2024 at 6:47 PM
Innova has a support line, I would give them a call.
Apr 12, 2024 at 7:32 PM
