pedal goes to floor brake light on?
2003 CHEVROLET TAHOE
11 MILES • 4.8L • V8 • 2WD • AUTOMATIC
NNHALO360NN
I am an 18 wheeler mechanic so my knowledge of hydraulic brakes is slim. Just changed front and rear brakes. When i changed the front left brake fluid overflowed from the reservoir when i compressed the caliper but only on that wheel. After replacing all the brakes i went to test drive but brake light was on and pedal goes to the floor. I tried engine off and pump the brakes hard then start engine but still did not help much at all. When i unplugged the sensor in the proportioning valve the light goes off. I read somewhere i need to reset the valve but unsure how. Main question, should i try and reset the valve or is my problem else where? Also i did not bleed the brakes.
Mar 30, 2019 at 3:51 PM
Good evening,
This sounds like the seals failed in the master cylinder. I would get a replacement master cylinder, bench bleed it and install. I would suspect there is air in the lines. These guides can help you fix it.
https://youtu.be/w7gUsj2us0U
and
https://youtu.be/WDxvEQrMkBg
and
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Please run down these guides and report back. Roy
Feb 19, 2021 at 9:24 AM
NNHALO360NN
Would this be why so much fluid leaked back out when compressing the calipers?
When you pushed back the calipers, the fluid went back up into the master cylinder and forced its way out of the cap. That is normal.
