Check engine light was on and car just began to run bad. Replaced the crankshaft position sensor since the camshaft sensor was previously replaced. Still ran bad and check engine light was still on. It threw up a different code saying misfire on cylinder one. Checked the spark plugs and had a small amount of oil on one of them. Changed valve cover gaskets and spark plugs. The car is still running bad, and now has a flashing check engine light with no codes coming up. This is a used car I have only had it a couple of weeks.
Mar 19, 2018 at 5:43 PM
