Pdk fault, code p0843
2014 PORSCHE PANAMERA
60,000 MILES • 3.0L • V6 • 4WD • AUTOMATIC
SEVAG P
  • 405 POSTS
Hello, I'm Sevag a Porsche technician works for Porsche center Lebanon.
I got a fault code p0843 short to b+. First step I checked the wire for the pressure sensor was good no short appear,erase fault test drive after 120km fault appear again for test run outside wire for the effected pressure sensor pin same fault appear again, after that replace the pressure sensor problem not solved replace pdk control unit same fault still appear every time fault reappear after driving more than 100km. vehicle battery and alternator are in good condition. Piwis tester is the latest version I don't know what I'm missing all the possible causes are done fault still appear.
Dec 23, 2018 at 10:40 AM
You have replaced the PDK controller and the pressure sensor. In my mind, that leaves one of two possible problems. First, there is a wiring issue that is intermittent and checks good when you test it. Or, there is an oil pressure issue.
Clutch 1, measured oil pressure > 21 bar
Check the pressure to confirm it isn't too high. Something could be causing an issue.
That would create a problem with the sensor.
Recheck the wire between the pressure sensor and the PDK. Move it around, check the connection for damage, check the wire for internal damage.
Let me know,
Dec 24, 2018 at 8:57 PM
SEVAG P
  • 405 POSTS
Hello, thanks for your reply. transmission is already replaced, don't think that can be an issue over pressure inside the gearbox. The wiring is check no short to b+ or b-. he resistance of the wire is as specified, to make sure I remove the original pressure sensor wire and run outside wire from PDK cu to transmission but after 100 same fault appear p0843 with p181a.
This screen shot the I send is from your forum it is like my issue after replacing transmission and cu he got fault code p0846 pressure sensor 2short to b+ and mine is p0843 pressure sensor 1. not mentioned at the end what was his solution I wanted to know please.
Dec 24, 2018 at 11:24 PM
Welcome back:
I was unaware of the P181A. That is the opposite end of the spectrum as far as pressure. When that code is set with P0843, the problem is usually related to sensor grounding and not a short to B+. Are you sure the ground is equally as good?
I'm sorry. Not being there to see what exactly is happening and how things are being checked makes it difficult. I hope you understand.
Everything I have checked indicates when both codes are present, there is a ground problem.
Dec 25, 2018 at 6:24 PM
SEVAG P
  • 405 POSTS
Thanks for your reply .I double check the ground for sensors also good.
Please I sent you a screen shot from your forum that has same problem of my car .can have the result what's happened in the end? I send the screen shots in previous massage.
Dec 25, 2018 at 10:59 PM
Hi:
I'm sorry but there was no resolve to that problem listed. If the tech found one, he never posted it. I checked for you.
Dec 26, 2018 at 6:07 PM
SEVAG P
  • 405 POSTS
Thanks for your help I appreciated, my best regards.
Dec 26, 2018 at 6:45 PM
Sorry I wasn't of more help. Take care of yourself and I still think it is a grounding issue. LOL If you determine the cause, would you let me know?
Dec 26, 2018 at 7:17 PM
SEVAG P
  • 405 POSTS
Okay, I will let you know the result we are at Christmas holiday until January 2.
Dec 27, 2018 at 1:29 AM
Same here. Take care and Merry Christmas.
Dec 27, 2018 at 2:49 PM
SEVAG P
  • 405 POSTS
Hello again I just want to update you that my problem solved by replacing pdk internal harness set that the transmission was new.
Thank you
Jan 9, 2019 at 10:06 AM
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
