PCV valve needs change
2010 SCION XD
130,000 MILES • 4 CYL • AUTOMATIC
MAXIMAX
Where is it locate and how often we need to do the replacement?
Oct 28, 2020 at 2:42 AM
I attached the info from the manual on the PCV. Let us know if you need more info. Thanks
FYI the last attachment shows the part number and labor time to give you an idea of how involved it is. This shows 2.3 hours to replace it so it is not the easiest to replace.
Oct 28, 2020 at 12:45 PM
MAXIMAX
Dear Sir ,
Thank you so much for your fast reply, I was hoping that i was wrong about the location, i have the same print out , but the year was 2008 Scion XD.. Don't understand why it is all the way down there, since most of the car i see was on top and easy located and replaced. Thank you for taking the time with me it will be all day project. I think i will have to get it started soon. Please take care and again, thank you for taking the time, Sir.
Oct 29, 2020 at 9:46 AM
You are welcome. I was surprised as well the first time I saw that. Clearly they did not have the repair people in mind when they did it. Thanks for using 2CarPros.
Oct 29, 2020 at 6:12 PM
