I have oil going through the breather tube tube on the front of the engine going to the air intake. I read online that the PCV valve is usually the issue and needs to be changed. I was searching for it and can not find it anywhere. I went to the parts department at the GM dealership and they did not know either. I need to find the location so I can change it. Is there anywhere to get a diagram showing where it is (nothing found for the 3.6L online), or might you know. Thanks Dave.
May 28, 2019 at 4:20 PM
