PCV replacement?
2002 SUZUKI SWIFT
100,000 MILES • 1.3L • 4 CYL • 2WD • AUTOMATIC
YOSEF LEVY
  • 7 POSTS
Install new PCV, the new one is a little bit slack. strange because seems the same product (see attached).
Regards
May 30, 2023 at 8:12 AM
Yep, they seem the same, what do you mean by slack? Here is how to install a new PCV in the images below. Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
May 30, 2023 at 6:29 PM
YOSEF LEVY
  • 7 POSTS
As you can see in the attached video, PCV does not look stable.
https://drive.google.com/file/d/1ID1gQ_IaiRq3m4clcXK1-Hv2dpX_jxze/view?usp=sharing
Regards.
Jun 25, 2023 at 12:38 AM
Thanks for the video, it does look like the grommet needs to replaced the valve has too much play causing a leak.
Jun 25, 2023 at 11:51 AM
