I replaced my two old o2 sensors recently with two new OEM (up and down stream) sensors. I however noticed a discrepancy in addition to having an 1157 obd2 code now. My new upstream o2 sensor has one white wire (i guess ground), one blue wire (i guess signal) and two black wires (heater). I measured 1.9 ohms across the heater. The colors on the junction connector coming from the PCM (and ultimately connecting with the o2 sensor connect-block), are different (2 red wires, 1 green and 1 white), which is cool, but the 2 red the wires coming from the car’s PCM are lining up with the white and black wire on the o2 a/f sensor and the green and white PCM wires line up with the black wires on the a/f o2 sensor connector block (please see sketch). I am confused, how can the 2 PCM red wires connect with the white and blue on the o2 sensor and the green and white with the black wires on the o2? Based on the way the colors are lining up, i need to conclude that one of the PCM red wires is a signal wire and the other red a ground wire, while the green and white wires would be for the heater? To me this does not make any sense? Can anyone explain this to me. Thanks.
Sep 18, 2019 at 9:54 PM
