PCM wiring diagram
2009 FORD ESCAPE
145,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
MICKCOOK
PET not working, won't crank.
Aug 28, 2025 at 12:50 PM
MECHTRIX
  • 382 POSTS
I think you meant the p.a.t.s (passive anti theaft system) it has to do with the security system / the imobiliser not recognizing the key it seems that it has locked you out it might need to be reset also its a comon accurance when you have a weak or dead batery or if there an issue with the transponder in the key on Ford vehicles good luck.
Aug 28, 2025 at 6:07 PM
The PATS system will not make the engine fail to crank over FYI.
Sep 5, 2025 at 10:20 AM
