After replacing fuel pump and filter, vehicle would still not start. I tested the wires going to the fuel pump, and they test about 7 volts. The power at the relay is 12 volts. I traced 7 volts as far back as the inertia fuel shutoff located by the kick panel on the passenger side. The wiring diagram shows two other connectors between the inertia fuel shutoff and the relay, but I can't seem to find them. Can anyone help me locate these connectors? They connect a dark green and yellow wire. In the diagram, they are labeled S127 and C147, if my memory serves me correctly.
Feb 5, 2021 at 9:29 AM
(Merged)
