After having the issue my vehicle threw two new codes: P1698 no communication from TCM for more than 10 seconds and code P1687 no PIC/BUS msg received. This happened after vehicle was parked for 45 minutes I cranked it to leave and display started to ding and check gauges light came on. I smelled melting wires so I cut engine off. It would not crank again afterwards. I reset codes and disconnected negative terminal but don’t want to try to crank it and damage it further. The smell was coming from the PCM location even after vehicle was towed home hours later. My question is this, will you come fix my car? If not, what do I do to narrow down what the issue is?
Feb 20, 2021 at 7:26 PM
