The first thing I would do is check the scanner in another car to see if it works, next check the fuse # 5 - 15 amp in the central fuse panel at the right end of the dashboard. This guide can help:
Here are the wiring diagrams for the ALDL connector and a guide to help you check the power and ground for the system. You may have a bad PCM.
Here is how to change the engine control module out in case you need it, you can get a preprogrammed unit by searching Google or Ebay. Check out the images (below). Please let us know how it goes.
Jul 18, 2023 at 11:33 AM
