The car randomly dies, but within 15 seconds will start back up. It is only been happening for about a month and it's starting to happen more frequently and becoming harder to start. I had two codes come up one for shift solenoid the other was for PCM, ECM. I was told that the PCM and ECM were two different things PCM you can replace yourself and ECM dealership had to do because of reprogram the car. With the only symptoms being randomly shutting off and my heat not blowing out hot air all the time. How do I know which to replace without costing an arm and a leg. And how much of it is the ECM should it cost to replace or how many hours of labor should it take?
Mar 21, 2017 at 11:21 AM
