Could I get a diagram of the PCM wiring out to the engine sensors?
2007 FORD F-150
260,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
DANIELR
MEMBER
FOLLOW
IE; MAF, fuel rail pressure sensor, etc.
Oct 24, 2024 at 7:43 PM
AL514
CERTIFIED EXPERT
Hello, yes, we can get that ready for you in a few minutes.
Oct 25, 2024 at 6:17 AM
AL514
CERTIFIED EXPERT
These are the OEM Ford PCM diagrams, do you need the PCM connector pinout diagrams to go along with this?
Oct 25, 2024 at 6:26 AM
AL514
CERTIFIED EXPERT
These are all 3 PCM connector pinouts and hopefully the correct location on the PCM as well if needed. But try to go by wire color and location in each connector to be sure.
