Cannot reset PATS System
2005 MERCURY MOUNTAINEER
100,000 MILES • 4.0L • V6 • AUTOMATIC
EARL UMPHRIES
Fuel pump and starter shut down. can't reset pats system. all relays and fuses good will start and run if power starter and fuel pump.
Jan 16, 2022 at 3:05 AM
SQM
  • 6,383 POSTS
Try this method to see if that helps to reset the passive anti-theft system (PATS):
Hold the panic button on the key fob for 2 seconds.
Close all the doors and while using the key lock and use the key to unlock the lock the driver's door.
If that doesn't work remove the negative battery cable for 15 seconds and reconnect.
https://www.2carpros.com/articles/how-to-reset-a-security-system
It that does not work you will need a scan tool to reset the PATS.
I have attached the instructions below.
Thank you
Jan 16, 2022 at 12:12 PM
EARL UMPHRIES
Thank you! I've tried everything but the scan tool reset. Will update results as they unfold.
Jan 16, 2022 at 12:34 PM
SQM
  • 6,383 POSTS
You are welcome. Keep me posted.
Jan 16, 2022 at 12:57 PM
