pats system/lost keys
1999 LINCOLN CONTINENTAL
200,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
PATRICK KIRKBY
i want to bypass the security system. lost keys to car replaced lock cylinder with a non-transponder key tumbler. since no one has found a way to bypass or hot wire this car. i want to know if i have the key and transponder box out of my 2005 Explorer can i plug the transponder and tape the key to it and place it near the column? can i program it to the car and use new ignition tumbler? i just need to start the motor to show it runs so i can sell it.
Dec 10, 2019 at 8:58 PM
SCGRANTURISMO
  • 4,897 POSTS
No, you can't. There is no way to bypass Ford's Passive Anti Theft System[PATS]. There are literally billions with a b of combinations and the PATS module is programmed to the Power-train Control Module [PCM} or "computer" so swapping PATS modules between vehicle's will not work. You will have to get a ignition lock cylinder with PATS programmable keys and have the keys programmed to the vehicle by either a locksmith or the dealership. There are no other options here.
Thanks,
Alex
2CarPros
Dec 10, 2019 at 9:29 PM
STEVE W.
  • 15,113 POSTS
Your idea will not work as they use two different transponder signal systems as well as different modules and key-codes. If you have the original cylinder most locksmiths can cut replacement transponder keys and program them into the security system as well.
