The passenger side, front door lock and power window switches remain illuminated after the vehicle is turned off. All three of the other door switches which are backlit while the key is on are no longer lit as soon as the car is powered down. The passenger front door is the exception. I have confirmed removing the 25A fuse, #26 from the right rear fuse compartment causes the switches to go dark. If this is an issue with the right front door control unit, is there a way to test this to confirm that before replacing it? I assume it is located behind the door panel, correct? Are these plug and play replacement? In other words, it does not need to be coded or programmed, correct?
Nov 12, 2018 at 2:51 PM
