Passenger side window front and back and power window into the bed stopped working all at once.
I check the 15 amp PCM fuse and it was good. Changed the passenger side circuit breaker under the steering column and it did not help. I changed the switch and that did not help. It does click when used. I took apart the passenger side door and power is getting to the switch. No power is getting to the motor when using the switch and the ignition on. Both brown and blue wires that go to the motor get no power out of the harness. Not sure what to do next?
Sep 23, 2016 at 10:01 AM
