Hi, I believe i am having a weird issue. My passenger side low beam turns off and does not work. I have changed the fuse. it worked for 2 days. This issue has happened 4 times (10 days in the past). When it does not work, I was told by a auto store person that it could be corrosion in the socket (where the bulb fits). so I removed the bulb, cleaned the socket and inserted the bulb and then the bulb works for 2 days and then turns off. The bulb that works on driver side is actually Sylvania XtraVision Headlight Bulb H7XV and the bulb that does not work is SilverStar Ultra Headlight Bulb H7SU-2. is it possible that this issue is because i have 2 different H7 bulbs from Sylvania or is the socket faulty? why is the bulb working for 2 days if I simply remove the passenger side low beam bulb and put it back without doing anything? the driver side low beam bulk works always with no issues. I did have an accident previously on the passenger side and had changed the entire headlight set like 4 years back not sure if that has anything to do. I am planning to put a Sylvania h7SU-2 in the driver side (so that both sides have the same type bulb) and see if that solves the problem. any other suggestions?
May 5, 2021 at 5:50 AM
