Okay, so my A/C was working great then out of nowhere it started going bad, the driver side is good. Passenger and rear vents are not, however. Changed the passenger HVAC blend door actuator, then the passenger side started blowing semi cool air when it was set to hot air on passenger side, the actuator broke a gear again, so I saw on another forum someone just taped the vent to the open position for cold air. My A/C then started blowing warmer air through all vents, evacuated the system, changed the compressor, and recharged the system. Now the A/C will run for a few minutes, slow way down for about 8-10 secs, go to full power for a few and repeat the cycle for the first 10-15 minutes of driving, after that it runs full power but still no cold air on pass side.
Now we are back to square one, the driver side is blowing cold air and the passenger side is blowing semi cool air, while the rear center vents are blowing warm air. If I was the only one in the car, not a big deal, but I drive with a child and I live in the desert where it's 120 degrees right now.
Any suggestions?
Any suggestions?
Jul 22, 2023 at 9:14 PM
