Passenger side headlight pin color location needed?
2016 KIA OPTIMA
132,000 MILES • 2.4L • 2WD • AUTOMATIC
DOUBLE F
A mouse ate the passenger side 14 pin headlight plug. Can't see the colors of wires. New plug came with all black wires. Needing location on plug where the colors go. 2016 Kia Optima with LED accents
Apr 29, 2025 at 5:15 PM
STEVE W.
  • 15,113 POSTS
Rodents are such fun. Strip the harness back and trim the wires. Pin 1 is pink. Pin 2 is red with battery voltage. Pin 3 is the blue wire for the turn signal. Pin 4 is empty. Now there should be 5 black wires that are all grounds in the harness, those go to pins 5,6,7 and 10 (add pin 14 if it has auto leveling). Pin 8 is empty. Pin 9 would be orange (with battery power for auto leveling) Pin 11 is also orange but won't have battery power. Pin 12 is yellow, for the parking light. Pin 13 is Green for the auto leveling. The connector diagram is looking into the open end of the connector, the new one should be marked though.
Apr 29, 2025 at 6:27 PM
DOUBLE F
Mine has 2 pink 2 yellow 3 black green blue. 2 orange the red and blue for the air bag sensor, a lot of colors don't match.
May 3, 2025 at 3:58 AM
STEVE W.
  • 15,113 POSTS
What is your VIN number? This is a US registered vehicle correct? If I look at the 2015 Korean built car I find 2 pink wires but they didn't use a 14 pin connection, only 10.
May 3, 2025 at 7:20 AM
DOUBLE F
5XXGU4L38GG017394 is the VIN# It's a 2016 Kia Optima US registered car. 14 pin connector.
May 6, 2025 at 7:54 AM
STEVE W.
  • 15,113 POSTS
Okay, ran the VIN and got the same wiring that I posted earlier from three different information sources. OEM from KIA, Alldata and Mitchell. That is for the 14 pin connector on the back of the headlight.
May 6, 2025 at 2:36 PM
