Van listed above is the LE model. I have tested the bulbs and the fusses and the relay, they are fine, the power +12V goes to the relay and from the relay. it goes to the left and right fusses(15A) and it goes out from the fusses, but, it doesn't reach the headlight low beam bulb connector. any suggestions my friend?
Note: the driver side low beam headlight is working normally and also the high beam headlights are working normally too.
I didn't found the hot on the plug, I found only the ground.
Dec 13, 2019 at 2:52 PM
