There is a weight sensor inside the passenger's side seat that sounds like it went bad, so can I ask if there is anything sitting in the seat such as a book etc.? If not let's run the airbag codes. Here is a guide to show you how with the instructions on how to swap the seat sensor out the images below in case a code comes up for it:
https://youtu.be/gnSGfEqrf_w
You can do a CAN scan as well; you can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Seat Weight Sensor
Vehicles equipped with the Occupant Classification System (OCS) have a seat weight bladder and pressure sensor unit that is integral to the passenger front seat cushion. The pressure sensor receives a nominal five volts and a ground through dedicated hardwired circuits from the OCM. The OCM then monitors the pressure sensor output voltage. Check out the images (below). Please let us know what happens.
Jul 13, 2023 at 4:01 PM
